Hi,
I'm encoding a film with the big 3 (BatchCCEWS 0.1.9.7 Beta5, CCE 2.70.01.05)
I have it configured for Robshot batch multipass, 5 passes,
The thing is OK till the first pass, I see the size I want (3500MB), but from second pass on the size change to only 380 MB.
And that happens with the three other files I have to encode from this DVD, all with wrong sizes.
Thanks in advance
Results 1 to 9 of 9
No, it doesn't. I also reinstalled CCE and even used a different CCE version, and always end up with a wrong size, very small.
I think it must be something affecting this film and CCE. I've been using CCE for years and it's the first time something like that happens.
Yesterday I encoded the same film with Procoder and had no problem at all -
Never been a fan of constant quality encoding for this very reason. Some swear by it, but I find that it has a tendency to to produce some very odd output.
I can suggest two things to try
1. Use an avisynth script to shield CCE from the original avi file. Something in the original encoding might be putting it off.
2. Set a proper multi-pass VBR encode using a max/min/avg bitrate setting for your running time and target file size.Read my blog here.
You can set Q-Factors only in 1-pass VBR.
And I use CQ encoding as often as I can (usually for DVD extras). -
Sorry if I didn't explain it well.
I use Multipass VBR with max/min/avg bitrate.
I just posted the Q factor because I thaught it was relevant for the settings, even if I use the VBR multipass. I thaught the vaf prior to all the passes from the multipass uses that Q factor.
Anyway I never had this problem size with CCE. I think I'll have to wait to the next film I encode to see if it happens again and it's a serious problem.
What's wrong with my video? It looks weird.
By bojadada in forum RestorationReplies: 11Last Post: 13th Jan 2010, 06:59 -
weird audio/video wrong-synced problem
By michcio in forum Authoring (DVD)Replies: 9Last Post: 11th May 2009, 14:23 -
Wrong size created
By craigarta in forum Video ConversionReplies: 0Last Post: 3rd Aug 2008, 18:20 -
CCE SP avi video wrong length
By skipadipadoo in forum Video ConversionReplies: 4Last Post: 7th Nov 2007, 12:14 -
Wrong Size at Spliting
By Flowbax in forum EditingReplies: 3Last Post: 16th Jul 2007, 14:33
