Hi,
Hope this is the right forum. If not, pls say so: I'll move it.
I hoped someone could give me an example of the folder/file structure on a HD-DVD (retail-movie).
Just so I can get familiar with it.
I did find the structure for SVCD and DVD on this site, but helas did not for HD-DVD.
Thx in advance.
As this is a emerging technology, we don't have a lot of info and guides for it yet. I assume you have been to our 'WHAT IS' for HD-DVD: https://www.videohelp.com/hd There are a few links there to other resources. AFAIK, they still use the basic DVD file structure, just some add-ons to take advantage of the increased capacity.
And you will have to PM a Mod to move a post, otherwise it's double posting and in violation of our rules.
And welcome to our forums. -
Go to http://www.doom9.net and look at the forums under the Decryption section. There's a lot of talk about the BackupHDDVD program and I think there are a few examples of directories there. I can tell you that I remember that VIDEO_TS, while it exists, is not used and some other directory is used instead. I also remember that instead of IFOs, HD-DVD uses what are called EVO files.
No,this forum is not about hd-dvd. Use the general forum for now. Moving you.
from pitch black hd-dvd
Code:/ADV_OBJ/DISCID.DAT 128 B /ADV_OBJ/menus.aca 10.33 MiB /ADV_OBJ/VPLST000.XPL 44.28 KiB /HVDVD_TS/BLACK.EVO 5.08 MiB /HVDVD_TS/BLACK.MAP 2 KiB /HVDVD_TS/CHASE03.EVO 14.87 MiB /HVDVD_TS/CHASE03.MAP 2 KiB /HVDVD_TS/CHASE07.EVO 16.38 MiB /HVDVD_TS/CHASE07.MAP 2 KiB /HVDVD_TS/CHASE13.EVO 23.6 MiB /HVDVD_TS/CHASE13.MAP 2 KiB /HVDVD_TS/CHASE14.EVO 21.66 MiB /HVDVD_TS/CHASE14.MAP 2 KiB /HVDVD_TS/CHASE16.EVO 21.02 MiB /HVDVD_TS/CHASE16.MAP 2 KiB /HVDVD_TS/CHASE20.EVO 24.07 MiB /HVDVD_TS/CHASE20.MAP 2 KiB /HVDVD_TS/CHASE25.EVO 23.26 MiB /HVDVD_TS/CHASE25.MAP 2 KiB /HVDVD_TS/CHASE26.EVO 19.52 MiB /HVDVD_TS/CHASE26.MAP 2 KiB /HVDVD_TS/CHASE27.EVO 21.77 MiB /HVDVD_TS/CHASE27.MAP 2 KiB /HVDVD_TS/CHASE39.EVO 22.42 MiB /HVDVD_TS/CHASE39.MAP 2 KiB /HVDVD_TS/CHASE40.EVO 23.17 MiB /HVDVD_TS/CHASE40.MAP 2 KiB /HVDVD_TS/CHASE47.EVO 18.74 MiB /HVDVD_TS/CHASE47.MAP 2 KiB /HVDVD_TS/CHASE53.EVO 15.72 MiB /HVDVD_TS/CHASE53.MAP 2 KiB /HVDVD_TS/CHASE55.EVO 17.93 MiB /HVDVD_TS/CHASE55.MAP 2 KiB /HVDVD_TS/CHASE56.EVO 7.36 MiB /HVDVD_TS/CHASE56.MAP 2 KiB /HVDVD_TS/CHASE63.EVO 22.29 MiB /HVDVD_TS/CHASE63.MAP 2 KiB /HVDVD_TS/CHASE76.EVO 15.42 MiB /HVDVD_TS/CHASE76.MAP 2 KiB /HVDVD_TS/DARKFURY.EVO 63.71 MiB /HVDVD_TS/DARKFURY.MAP 2 KiB /HVDVD_TS/FEATURE_1.EVO 2 GiB /HVDVD_TS/FEATURE_1.MAP 26 KiB /HVDVD_TS/FEATURE_2.EVO 2 GiB /HVDVD_TS/FEATURE_2.MAP 22 KiB /HVDVD_TS/GAME.EVO 71.03 MiB /HVDVD_TS/GAME.MAP 2 KiB /HVDVD_TS/HVA00001.VTI 20 KiB /HVDVD_TS/INTRO.EVO 111.38 MiB /HVDVD_TS/INTRO.MAP 2 KiB /HVDVD_TS/MAKING.EVO 217.38 MiB /HVDVD_TS/MAKING.MAP 4 KiB /HVDVD_TS/MENU.EVO 111.89 MiB /HVDVD_TS/MENU.MAP 2 KiB /HVDVD_TS/RAVE.EVO 1.22 GiB /HVDVD_TS/RAVE.MAP 10 KiB /HVDVD_TS/UNILOGO.EVO 72.3 MiB /HVDVD_TS/UNILOGO.MAP 2 KiB /HVDVD_TS/VIEW.EVO 176.78 MiB /HVDVD_TS/VIEW.MAP 4 KiB /HVDVD_TS/VISUAL.EVO 24.73 MiB /HVDVD_TS/VISUAL.MAP 2 KiB /HVDVD_TS/VISUAL_INTRO.EVO 32.43 MiB /HVDVD_TS/VISUAL_INTRO.MAP 2 KiB /HVDVD_TS/VISUAL_LOOP.EVO 30.15 MiB /HVDVD_TS/VISUAL_LOOP.MAP 2 KiB /HVDVD_TS/VISUAL_MERC.EVO 27.92 MiB /HVDVD_TS/VISUAL_MERC.MAP 2 KiB /HVDVD_TS/VISUAL_ORRERY.EVO 21.46 MiB /HVDVD_TS/VISUAL_ORRERY.MAP 2 KiB /HVDVD_TS/VISUAL_SLAM.EVO 27.44 MiB /HVDVD_TS/VISUAL_SLAM.MAP 2 KiB
Thx for all the great hints so far. It'll kickstart me in the right direction for sure.
Wgat would be the proper folder structure to add movie cover to a folder
By VoodooEvil in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2012, 19:09 -
jpg folder in dvd structure
By PharmBoy in forum Authoring (DVD)Replies: 4Last Post: 22nd Jan 2012, 18:38 -
minimum blu-ray folder structure
By tommyjw in forum Newbie / General discussionsReplies: 5Last Post: 12th Aug 2010, 20:51 -
Blu-Ray T.V. Folder Structure & WMC
By carlos28355 in forum Blu-ray RippingReplies: 0Last Post: 3rd Jun 2010, 14:09 -
Make Blu Ray folder structure w/o re-copying the m2ts file
By stew181 in forum Authoring (Blu-ray)Replies: 3Last Post: 9th Jan 2010, 10:14
