Results 1 to 11 of 11
    Jan 2007
    nero giveing eror win i use shirnk when it goes to nero it gets about one quart an brings up eror ahead nero winespi 32.dill ver 2.0.1.6:ver=2.01.68 and winaspi 32 dill:ver 4-60{{1021 i am missing mpge 2 i ran a detective solfware an found this i downloaded the mpge 2 file with win zip an estracted to several places but window medea still want play my movie i did some cleaning with reg cleaners and fhen this any help please
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    hloy siht ane1 got a dictnery ?
    How's about taking your time, rephrasing your post and clearly spelling out the exact error message you get and any other vital information ?
    If in doubt, Google it.
  3. Originally Posted by rod641
    Your post is VERY hard to understand.
    However, if I do understand it, you have downloaded an MPEG2 encoder file of some sort but your computer doesn't see it.
    Most likely it is a DirectShow filter and you need to register it with the computer.
    You need to do this:
    Go to Start Menu
    Choose Run...
    Type 'cmd' in the box and press Enter (don't use the quotation marks)
    You'll see a Command Prompt window open
    Type each of the following, press Enter at the end of each line
    c:
    cd \windows\system32
    regsvr32 <the file you downloaded with quotation marks around the full path>
    exit
    If the file you downloaded is mpeg2enc.dll (for example) and you put it in c:\documents and settings\rod641\my downloaded file then the third line above would be exactly this:
    regsvr32 "c:\documents and settings\rod641\my downloaded file\mpeg2enc.dll"
    You must type everything accurately...
    John Miller
  4. Mod Neophyte redwudz's Avatar
    USA
    That may be difficult.
    rod641, you will get more answers here if you use punctuation, sentences and paragraphs to make your posts easier to read. But follow JohnnyMalaria's advice and you should have a good start.
    You might try using VLC Media Player as it uses it's own codecs and doesn't rely on the system codecs if you just want to play back a file. If that works, then you have a codec problem. Windows doesn't come with a MPEG-2 codec. You have to install one.
    Also a program like Gspot 2.60 will tell you which codecs you need. If you are using Shrink to back up a DVD, then you may have an encryption problem. If so, use RipIt4Me before Shrink. And if Nero has problems with burning, ImgBurn is a better burner for DVDs.
    Moderator redwudz
    And welcome to our forums.
    Aug 2002
    cleveland, oh
    I agree with jimmalenko, posts such as this should be ignored till the author cleans them up.
  6. looks like a joke to me
  7. Member Xylob the Destroyer's Avatar
    Sep 2004
    Earth, for now
    sounds like he needs to re-install/upgrade his ASPI
    poor english is somewhat acceptable when the user's location indicates a non-english speaking country
    when location shows as "United States", lay into 'em hard
    if that post isn't a joke, he's the laziest poster I've ever seen. that shit's worse than when ******** try to post in ebonics.
    "To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
    "Megalomaniacal, and harder than the rest!"
    Jan 2007
    I am sorry about my english. I made Ds in english think you for understanding and think you for the help. I will try what you suggested.
  9. Originally Posted by Xylob the Destroyer
    Why? Not everybody living in the United States necessarily speaks (the US variety of) English.
    Remember how to make an ass out of you and me - there are plenty of reasons that someone may not be able to make a clear post in perfect English. What if the OP had a neurological disease that prevented him/her from typing easily and was using a non-familiar computer?
    Try to be accommodating, not elitist.
    John Miller
    Aug 2002
    cleveland, oh
    Well as his last post shows it can be done when he tries. No slack here.
  11. Member Xylob the Destroyer's Avatar
    Sep 2004
    Earth, for now
    Indeed, indeed. The US is essentially a nation of immigrants, but I also made D's (and a few F's) in English throughout High School.
    I think jameshgross hit the nail on the head -- laziness seems to be the culprit here.
