hi
im having problems trying to load svcd2dvd to windows vista.
i can down load the program but unable to register goes through the motions in registration wizard. i fill in my email addy and serial number i press next it gives me a registration code .
i press registtration tab then the box just disappears and nothing happens.
can any one help,
Drop me an email and we can try it manually...
Ok. But if you want further assistance - drop me an email and we'll try it offline as suggested.
No ones struggled trying to get svcd2dvd working in vista than i have well some might have anyway i have now sorted it and it works fine. All you have to do is install svcd2dvd on any drive except the one you installed Vista and it works fine. Done it on 3 seperate machine and all work fine. Good Luck
cheers for that . problem is my drives are sata raid set up may be thats why iv had problems.
Problems Using Snipping Tool (Windows Vista) with Blue Ray Discs
By rib in forum Newbie / General discussionsReplies: 0Last Post: 16th Feb 2010, 05:02 -
Windows 7 Ultimate - Can't load assets in SVCD2DVD
By ttyner in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 13th Jan 2010, 11:54 -
SVCD2DVD 2.5 Will Not Load
By Rower4VT in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 2nd Sep 2009, 14:25 -
VLC problems in Windows Vista
By 1234567 in forum ComputerReplies: 4Last Post: 8th Oct 2008, 17:45 -
SVCD2DVD Vista problems
By blondeguysteve in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Nov 2007, 10:35
