    Jan 2007
    Hi:
    I've been encoding MPEG4's to DVD format using the DVD ffmpeg target format. This last time after I created the encoded files and tested it using my DVD Player on my Mac I noticed the audio didn't match up with the video. When watching when people speak, the audio started before their lips moved by at least 1-2 sec. I've never run into this problem before. Is there a setting that needs to be set differently? I also noticed there was a warning message that stated "buffer underrun" after about 2-8% on the progrees bar.
    Any advise would be appreciated. Thanks
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    If the loss of sync is constant, i.e. the same time difference throughout the movie, then you can re-mux with a time-offset in milliseconds. See ffmpegX>Tools tab>Mux.
    Encoding with "Decode with QT" option activated might improve syncing.
