WHEN I TRY TO CONVERT MOVIES WITH ODD FRAME THROUGH TEMPG IT WILL STOP AFTER A PORTION HAS ENCODED AND GIVE ME A ERROR OF AN ILLEAGAL FLOATING DECIMAL PIONT.
there is a little freeware program called RAD video tools that you can use to convert a video to any frame rate you wish while keeping the audio in sync. You can find it here:
http://www.radgametools.com/bnkdown.htm
it also converts "*.mov" videos
good luck
baz
will this help with problem of the error that i am getting in tmpge that says ( illegal floating decimal piont). I am assuming that the abnormal frame rate is the cause but I am not sure.
Illegal floating point can also be a result of a corrupt frame. Try playing the avi in Virtual dub. It will stop and give you an error message if there is a bad frame.
convert .mkv with non-standard frame rate
By Conrad007 in forum Video ConversionReplies: 2Last Post: 20th Jan 2011, 11:50 -
Trying to convert World Cup game to DVD, have a ? about frame rate
By Roge in forum Authoring (DVD)Replies: 8Last Post: 10th Sep 2010, 06:06 -
odd frame rate problem
By deadrats in forum Video ConversionReplies: 0Last Post: 7th Dec 2008, 13:32 -
HELP! FRAMe RATE CONVERS. TO MAKE IT MOVIE LIKE!
By Jadekay in forum Video ConversionReplies: 10Last Post: 6th Aug 2007, 22:56 -
Is there a program that can safely convert variable frame rate videos?
By darkzero297 in forum Video ConversionReplies: 1Last Post: 17th Jul 2007, 20:01
