Now, whenever I play a DVD with PowerDVD or Windows Media Player , i get a green screen. I thought that it must have somethign to do with the overlays but changing those settigns didn't work . I downloaded a codec pack (Klite full) and that didn t work too . So, I uninstalled Nvidia Drivers and reinstalled it. When it was uninstalled i could play the dvd without the green but when it was reinstalled, the green screen was back . Can anyone help me ??![]()
Only one player at a time can use the graphics card's video overlay feature. Since the second player isn't using overlay and has a normal picture the problem lies with overlay. Now that you know for sure where the problem lies you can look for solutions.
Look through the graphics driver's advanced features dialogs. If there is an overlay enable/disable option try turning it off (it may be necessary to reboot for the setting to take hold). Play a video -- it should now be normal. Go back and turn it on (overlay has many advantages so you want to use it) and play a video again. This is often enough to fix the problem.
Green Screen Advice
By HoosierGuy in forum Newbie / General discussionsReplies: 19Last Post: 8th Mar 2011, 09:53 -
Pinnacle DVD menu green screen SOLVED!
By Surg1951 in forum Authoring (DVD)Replies: 2Last Post: 27th Feb 2011, 16:12 -
Funny green screen
By timmythesaint in forum Newbie / General discussionsReplies: 18Last Post: 14th Apr 2009, 15:41 -
Screen turns green
By boysha in forum Newbie / General discussionsReplies: 2Last Post: 31st Dec 2007, 14:46 -
green screen when capturing
By HDMI in forum Capturing and VCRReplies: 1Last Post: 30th Jul 2007, 12:37
