Hi all. So far I am able to capture w/VirtualDub using the Huffyuv vers 2.1.1 to an avi, from there I can create a VCD with good quality (I followed the procedure in vcdhelp.com web site. Thanks for the great help).
Here is my problem: If I want to add some special effects or cut/modify the scenes to the movie (editing the AVI) I have to use a commercial program like VideoWave/ULead (I do not know about Premiere with the Panasonic codec) but when I use any of them the output to VCD loses lots of quality (somewhat heavy squares and blur)
Is there a commercial package or settings that is recommended for these tasks
Any suggestions?
TIA
Results 1 to 1 of 1
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 14:46 -
How to add watermark to VCD without Re-Encoding?
By shebi in forum Authoring (VCD/SVCD)Replies: 25Last Post: 26th Apr 2009, 09:26 -
PAL VCD -> Proper NTSC DVD w/o Re-Encoding?
By SanctimoniousApe in forum Video ConversionReplies: 8Last Post: 4th Apr 2009, 17:59 -
Tool for VCD at 2500 bitrate with No Re-encoding
By whenloverageswild in forum Authoring (VCD/SVCD)Replies: 21Last Post: 6th Mar 2009, 11:34 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 16:56
