    Apr 2006
    Pakistan
    Hi
    Long time back while using google i ended up this site and i found a link to a guide on how to capture AVI using virtualdub. Sadly i lost the link and after formating my drive i have lost my settings.
    I only remember that the framerate mentioned on that webpage for capturing was 29.970.
    please post the link if you guys know about it.
    P.S: it also had the heading "capture avi using virtual without dropping frames"
    thanks in advance
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Possibly this one? https://www.videohelp.com/guides.php?guideid=130#130
    Just look in the ALL GUIDES section...all of the guides are listed there.
    Google is your Friend
