Can you help, i had a virus in my external HD,i've manage to get rid of the trojan but for some reason my HD keeps crashing or shutting down.
When this happens it effects the my pc because if i'm on the net and my external HD will freeze everything so i've got to turn off my HD for me to continue with what i'm doing,does anyone know what the problem is and how i can sort the problem out.Also i'm getting popups,i've tried to shhot the manager but still no joy.
Please post in the correct forum. Moving you to Computer.
/Mats -
Ad-aware se , install , update , scan , crush all item's listed .
Hijackthis , scan system , uncheck those item's not required during startup ... quicktime , itune's , itune's helper , messenger , let it fix , and reboot .
Rescan , if item's appear , and you dont know if they should be listed , do a search with google should return result's ... post log .
Start , settings , control panel , power option's ... set all to never , apply , ok .
Windows explorer , tools , folder options , view tab .
Check "show hidden folder's and file's" , and the two options below this , answer yes to popup box , apply , ok .
Go to document's and setting's , local settings .
Empty both the temp folder , and the temporary internet folder .
Reboot pc .
Avgfree , install , update , scan entire system .
Beware , some trojan's get into system restore and can only be entirely removed by turning this off , reboot , reset restore point .
Dont forget to empty out the virus vault ... trojans can still cause denial of net service's from here .
Net you say ... how .
If dsl via usb , change dsl to ethernet should help issue experienced with external usb enclosure .
Computer keeps shutting off
By black cloud in forum ComputerReplies: 18Last Post: 2nd Aug 2011, 22:54 -
Computer keeps shutting down
By mac71671 in forum ComputerReplies: 8Last Post: 29th Jan 2010, 10:45 -
By didikai in forum Newbie / General discussionsReplies: 22Last Post: 31st Aug 2008, 09:24 -
Folders keep shutting down?
By aelfheah in forum Newbie / General discussionsReplies: 12Last Post: 26th Feb 2008, 15:07 -
HV20 Shutting Down
By Seavemeyer in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 22nd Dec 2007, 23:57
