Hi all .could any one tell me what is the best setting for capturing using studio 10 plus and media center? I want later burn the captured content in to a DVD. I be happy if an expert give me advice here.Thanks
For analog material use a lossless codec like Huffy. Downside is you get enormous files and have to take the time to convert to MPEG
Many thanks for u reply. could u tell me how i can use that codec. Does my pinnacle sofware allow to use it ? i be happy if u tell me how i can use this codec with my pinnacle sofware.ThanksOriginally Posted by thecoalman
You should be able to use it and if not I'd get some different software. Autolink didnt work above, Downlad Huffy , if i remeber correctly directions for installation come with it .
Xvid Setting: 1pass Quantizer vs Bitrate Mode, vs 2pass => Quality
By carlaron in forum Video ConversionReplies: 12Last Post: 4th Oct 2010, 07:12 -
Best h.264 setting for optimal size/quality with handbrake.
By frickfrock99 in forum Newbie / General discussionsReplies: 4Last Post: 1st Oct 2010, 02:09 -
Resampling quality setting in Ulead VideoStudio
By eclipse95 in forum Video ConversionReplies: 20Last Post: 16th Sep 2009, 20:08 -
Help setting quality settings on mencoder converting videos on my website!
By funnyspo in forum Newbie / General discussionsReplies: 0Last Post: 12th Feb 2009, 16:55 -
Suggestions request for setting up PiP PC capture.
By Clickn in forum Capturing and VCRReplies: 0Last Post: 21st Apr 2008, 19:52
