All my hot keys are full on my keyboard and I was wondering, is it possible to set say the (H) key be a shortcut to a website?
Results 1 to 9 of 9
What We Do In Life, Echoes In Eternity....
I'm a little suspicious of just opening a zip file, can you explain what it is? So the only way to do this, is I would have to install a program. There is no way to just do this in winxp?
What We Do In Life, Echoes In Eternity.... -
Not that I know of, although that means little... Often it is the keyboard manufacturer who will bundle additional software with their product that allows you to do what the software I linked to above does. If you want something more mainstream, google "Autohotkey"
That I will. Thanks for your help so far
go to your favorites folder
right-click the shortcut to the site and choose properties
on the "Web Document" tab, click in the box for "Shortcut Key" and press the key on your keyboard that you want to be the key for that site.
click Apply and then OK
now when you press Ctrl+Alt+H, your site will open."To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
You are the shit Xylob...Thanks!
you might try using the numeric keypad keys instead of your alphanumerics
Letter being covered up by the letter next to it
By Cyan in forum SubtitleReplies: 4Last Post: 2nd Jan 2012, 07:05 -
Subtitling software that uses hotkey-based/"punch-in" timing method?
By wohdin in forum SubtitleReplies: 0Last Post: 12th Jun 2011, 13:34 -
Portable Scanner by VuPoint: how do i make scans fit 8x11 letter size ?
By vhelp in forum ComputerReplies: 4Last Post: 6th Jun 2010, 16:37 -
tools needed to make a streaming website
By mr-scarface in forum Video Streaming DownloadingReplies: 5Last Post: 29th May 2009, 18:49 -
Change the key of a song to another key?
By Ikka in forum AudioReplies: 4Last Post: 3rd Feb 2008, 13:27
