My question is can you chage what shows in the motion meni for each episode because i can only get the same 15 sec video ( is there any option some where else that i missed.) for the beginiing of each episode which does not really tell you whats in the episode.
My understanding is that you can set whatever you like to be the motion menu for each individual title or chapter so long as you use a dvd-compliant MPEG clip. Now this could be the first 15 seconds of each ep if you like, or you could create your own montage of the key points of the ep.
But bottom line is: dvd-compliant MPEG is all you need.If in doubt, Google it. -
i understand that is there any Tutorial with screenshots maybe that show this.
I haven't tried this yet, I just normally go with the defaults...Go to "Create Menu", Click on the Track or Chapter preview window and it should bring up the "Change Thumbnail Image", move the slider over to where you want it to start the 15 second preview and click ok...let me know if it works, I may start using it. (I'm using TmpGenc DVD Author 1.5 but I thinks its about the same).
menu problem in TMPGEnc DVD Author 3
By sanduul in forum Authoring (DVD)Replies: 13Last Post: 23rd Oct 2007, 19:20 -
TMPGEnc Author Version 2.0 - Unable to make a DVD with a motion Menu
By tug_hill2 in forum Authoring (DVD)Replies: 5Last Post: 28th Sep 2007, 00:37 -
TMPGEnc DVD Author 3 (MENU PROBLEM)
By jaffacaique in forum Authoring (DVD)Replies: 9Last Post: 18th Sep 2007, 19:43 -
TmpgEnc DVD Author 3 - Question About Menu Music
By heyjjjaded in forum Authoring (DVD)Replies: 10Last Post: 30th Jul 2007, 13:16 -
Menu troubleshoot using Tmpgenc Dvd Author
By tekka06 in forum Authoring (DVD)Replies: 8Last Post: 4th Jul 2007, 03:53
