I need to know if its work proper,
from DV to component with RS422 remote control.
What VTR do you plan to use? I've seen it used with Betacam SP and older U-Matic Sony decks (internal TBC models) but mainly as source decks for DV capture.
What are you dubbing to? -
It should work fine. Ask over in the Canopus Forums for user experience.Originally Posted by roma_turok
From you experience?Originally Posted by edDV
The video quality good? conversion from DV to Component and from Component to DV ?
The timecode from PC edited Timeline to Beta or from Beta to PC transform proper?
thanks -
I've used it on systems capturing from Betacam and UMatic to DV, not the other way. I didn't set it up but it worked fine controlled from Premiere Pro and Edius.Originally Posted by roma_turok
I don't know if they had installation problems. The system I was using had the jog/shuttle hardware controller. I forget the manufacturer name.
For DV to Betacam, seems to me manual cue and start is about as good. Unless the deck is remote.
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 19:26 -
Macrovision and Canopus ADVC 110
By nikgelfi in forum Capturing and VCRReplies: 2Last Post: 13th Apr 2011, 17:09 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 21:52 -
Capturing with Canopus ADVC
By BonnieW88 in forum Capturing and VCRReplies: 3Last Post: 29th Nov 2009, 22:55 -
Canopus ADVC-55 vs. ADVC-110
By bcags7 in forum Capturing and VCRReplies: 4Last Post: 2nd Nov 2008, 16:15
