I downloaded ffmpegX and the bianaries like I thought I was supposed to. Dropped in a wmv to convert MP4 H.264. I got the progress window and it completed almost immediately. I looked at the log and it says this....
Encoding started on Fri Jan 19 17:01:50 CST 2007
FIXME:Hardenabling SSE and SSE2 without detection
MEncoder dev-CVS-060307-04:23-4.0.1 (C) 2000-2006 MPlayer Team
Mac OSX static build for ffmpegX
CPU: Intel (Family: 6, Stepping: 6)
CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2
Exiting... (error parsing cmdline)
The ofps option must be a floating point number or a ratio (numerator[:/]denominator): -vop
What am I doing wrong? Thanks in advance for any help.
This thread would be better answered in our ffmpegX general discussion Forum. Moviing you.
We also have a Mac Forum for other Mac questions.
And omegastu, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:Thanks, Moderator redwudzTry to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
And welcome to our forums.
Check to see if the framerate is filled in (Video tab). If not, then fill in the framerate you want your output to be. If you want the same as the source file (advisable), then check QuickTime Player's Show Movie Info with Flip4Mac installed.Originally Posted by omegastu
If H.264 mencoder fails, then try H.264 x264. For the latter, in the Options tab, you may select/deselect Decode with Quicktime, whichever brings best results.
How to choose *separate* videos off one DVD for encoding in ffMPEGx
By DrLooby in forum Newbie / General discussionsReplies: 2Last Post: 20th Aug 2011, 21:13 -
Problem with artifacts when encoding to FLV using ffmpegX
By Leon_Cych in forum ffmpegX general discussionReplies: 2Last Post: 30th Apr 2010, 07:57 -
ffmpegX not encoding properly -- fails after 7%
By larrryc in forum ffmpegX general discussionReplies: 2Last Post: 22nd Apr 2010, 14:07 -
(some) MOV's not encoding to MP4 on ffmpegX
By DarkPhoenix77 in forum MacReplies: 2Last Post: 6th Oct 2007, 23:35 -
Strange Flicker in DVD with ffmpegX encoding
By angeloftheodd in forum ffmpegX general discussionReplies: 3Last Post: 2nd Jul 2007, 21:49
