The current release of Cyberlink PowerDVD Ultra 7.2 ONLY installs for ONE format either Blu-ray or HD DVD. By default with NO drive active (neither Blu-ray or HD DVD) on your PC the Blu-ray option will be installed.
To view the other format you must uninstall the current version and reinstall.
To install the HD DVD driver with NO drives installed:
Look into the PowerDVD folder. You will see two folders named "PDVDHD" and "PDVDBD".
Rename the "PDVDBD" to anything you want. Then rename the "PDVDHD" to "PDVDBD".
Start the installation as normal. Installshield *should* install the HD DVD version.
I believe Cyberlink is looking into this limitation of the software to enable both versions to be active.
Another limitation you are NOT able to capture any pictures.
This information as all been reviewed at the .AVS forum:
http://www.avsforum.com/avs-vb/showthread.php?t=773218&page=19&pp=30
Results 1 to 1 of 1
Powerdvd 10 3D Ultra how well does it work for converting movies to 3D?
By slowmost in forum Software PlayingReplies: 2Last Post: 27th Jun 2010, 00:53 -
PowerDVD 9.0 Ultra & Game Launching
By ChipMcC1 in forum Software PlayingReplies: 0Last Post: 12th Aug 2009, 02:10 -
PowerDVD 8 Ultra Has No Media Library for Audio
By vhsreject in forum Software PlayingReplies: 1Last Post: 12th May 2009, 09:52 -
powerdvd 7 ultra PROBLEMS
By swiss in forum DVD RippingReplies: 3Last Post: 19th Aug 2007, 16:24 -
Opening .IFO with PowerDVD Ultra
By kestrel07 in forum Software PlayingReplies: 1Last Post: 21st Jul 2007, 11:22
