I'm wondering if anyone could give me some suggestions for a good HDV capture card for my computer. I use Adobe Premiere Pro to edit and I just purchased the Sony HDR-FX1 camera.
HDV is captured using the Firewire interface - just like DV.
If your PC has Firewire already, you are set. Otherwise, you can buy Firewire interfaces for very cheaply.
You *may* need XP SP2 to support native transfer of HDV.John Miller -
Just about any Firewire (IEEE 1394, iLink) card will do. You want to avoid the absolute cheapest ones because they may be problematic. But once you get beyond that they will all give the same quality. Look to spend around US$20.
http://www.newegg.com/Product/ProductList.asp?N=2010010073+1187112432&Submit=ENE&SubCategory=73
All you're doing is "copying" the digital data from the camcorder to the computer so all cards will deliver the same quality. -
Currently I have a Canopus Storm2 & Drive Bay. I know they work for DV, but I'm not sure about HDV. I also edit with Adobe Premiere Pro 1.5 - I think I may need to upgrade this as well to edit HDV.
I know that the Canopus Storm2 I have isn't compatible with Adobe Premiere Pro 2.0 so I'm looking for some other sort of device to output my video to my video hardware for editing through my monitors and outputting the video/audio signals. -
You can get a free plug-in from Adobe for editing HDV with 1.5:Originally Posted by foochuck
http://www.adobe.com/products/premiere/hdv.html
For capturing etc, all you need is a Firewire interface.John Miller -
Awesome, thank you Johnny.Originally Posted by JohnnyMalaria
I used firewire with the Sony HD Cam and it worked fine. Glad Adobe is finally supporting it.
-=AE=-
Can't capture from HDV tape!
By frlane in forum MediaReplies: 8Last Post: 2nd Jul 2009, 16:43 -
HDV Capture Card Reccomendations
By SCDVD in forum Capturing and VCRReplies: 7Last Post: 9th Mar 2009, 15:24 -
HDV capture
By yonut in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 19Last Post: 25th Oct 2008, 11:33 -
HDV capture h/w and s/w reqmts
By vineetg in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 19th May 2008, 19:01 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
