<font size=-1>[ This Message was edited by: pepehdez on 2002-01-17 13:37:50 ]</font>
<font size=-1>[ This Message was edited by: pepehdez on 2002-01-17 13:41:21 ]</font> -
I've using DVD Movie Factory, it is very friendly, and menus are kind of cool, but I want something better. Which software should I use ?
Check The Menu I created it's a exact replica of the original DVD menu, too bad I made it in flash and I can't use it for my DVD Rip.
That more or less what I would like to use for my
DVD rips, what should I use ?
Almost forgot the magic word: HELP PLEASE !!
! Viva Mexico ! -
hello,
you can export the Flash movie to AVI, then convert that to DVD compliant MPEG, which can be used as a menu. as for authoring the menu, try http://www.Doom9.org. -
Thanks for your reply.
I can't do that because the buttons won't work, as you can see this menu is not just a movie.
Well, Pepe, that's just it:
Experts don't use Flash to create animated menus. Adobe After Effects perhaps, but not Flash.
It's like asking Van Gogh which crayons he used to create the painting Starry Night -- he didn't use crayon at all. -
To make the same menu you gonna need something like Pinnacle impression DVD-Pro, Scenarist ....
Impression is the cheapest and it works very find.
You have to export your Flash movie as a avi and encode it to a DVD compliant mpeg2 file and after this you have to make the all the menu elements in Photoshop. What and how is up to your authoring softwares needs.
How do I create a DVD Menu
By RKM1552 in forum Authoring (DVD)Replies: 6Last Post: 23rd Feb 2010, 12:19 -
How do I create a DVD menu?
By RKM1552 in forum Newbie / General discussionsReplies: 1Last Post: 23rd Feb 2010, 06:42 -
What program do you use to create a menu for DVD
By Cazz in forum Authoring (DVD)Replies: 6Last Post: 24th May 2009, 12:31 -
create a dvd menu from iso image
By DSLGuy in forum Authoring (DVD)Replies: 3Last Post: 19th May 2008, 09:30 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 11:36
