Possibly try extracting the audio from the mpg movie before you import. Then import the video and audio separately.
Google is your Friend -
Which version of DVDLab (Standard, Studio, or Pro)?
When you imported the mpeg, did you "demultiplex to elementary streams...", or use the "Quick mode without Demultiplexing"
Try "Demultiplexing" (either on Import, or on the Compile screen, select the "Demux to ES" option -- if that option is in your version)
Regards,
George -
Hi,
This is the first time I get this problem, because I alread made many DVD's with DVDlab.(version 1.1)
I always demultiplex to elementary streams and everything worked fine for a long time, except this mpg.
Maybe I can mail you a little piece of the mpg, that you can try.
If I can please give me your emailaddress.
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 11:25 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 17:24 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 04:12 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 01:19
