On videohelp it has the update listed as 3.0.6.0 but on DVDIDLE's website it only has 3.0.5.5.
Does anyone know why this is,and where I can get the 3.0.6.0 update?
Thanks in advance.
3.0.6.0 Beta (01/16/2007):
http://www.dvdfab.com/DVDFabDecrypter3060Beta.exe
- New: Added support for a new copy protection as found on "Saw III" (US).
- New: Batch processing for "DVD to Mobile", now you can convert several titles of several sources at one time.
- New: Updated language files.
- Fix: Crash problem when converting AVI with IDX/SUB subtitle.
- Fix: Several minor problems. -
I was running version 2.9.7.9. of DVDFab without a problem until I read the above post, and downdoaded version 3.0.5.5. However, after installing it, I got a "crash report" and the program didn't work. Trying to send the "crash report' to the e-mail provided didn't work either, so I installed 2.9.7.9. again.Originally Posted by Baldrick
I wasn't able to locate any versions between that old one, and the newest one, to find out at what point they started to crash on my system - so I would have been able to install the latest version that would not crash. -
Can't extract Saw III.Originally Posted by Baldrick
"Half empty or half full, it's still only half a glass" - What Dave Says
Best way to update DVDFab?
By stephens in forum DVD RippingReplies: 2Last Post: 11th Dec 2010, 13:38 -
DVDFab 7 HD Decrypter
By burnmaster in forum Blu-ray RippingReplies: 3Last Post: 9th Apr 2010, 08:11 -
DVDFab Decrypter
By HacktheHacker in forum DVD RippingReplies: 11Last Post: 25th Feb 2008, 23:10 -
DVDFab HD Decrypter???
By bltprf in forum Newbie / General discussionsReplies: 11Last Post: 9th Jul 2007, 00:09 -
DVDFab HD Decrypter 3.1.1.2 (05/12/2007)
By NICEBUD in forum Newbie / General discussionsReplies: 5Last Post: 15th May 2007, 20:07
