  1. I had bought some dual layer dvds and would like to know how can I backup a dual layer movie with Ripit4me. The movie I had bought is Superman and it says dual layer on the rear of the cover.
    Gerald Sr.
    Gerald Sr.
    Dec 2003
    RipIt4Me is only a ripping tool. For burning dual layer disks, I would recommend ImgBurn. It's also free. Read the guiides and good luck!!!
    Mako
  3. 69mako, I have the decrypter and nero to burn the dvds.
    Gerald Sr.
    Gerald Sr.
    Apr 2005
    Montreal, Canada
    Rip movie in ISO mode using RipIt4Me, then burn image using ImgBurn.
    Simple as that...
  5. Thanks r3n4ud for the info. Will imageburn conflict with nero burner?
    Gerald Sr.
    Gerald Sr.
  6. Member fatbloke88's Avatar
    May 2006
    I run both with no problems
