Is there a way to set it up to work the safest way without crashing like nero dvd rom? Like changing the speed or something?
If it is crashing it will be for one of three reasons
1. It is poorly written crap
2. It is not installed correctly, or the installation is corrupt
3. It is clashing with something else on your system
The best way to address it is through Nero support. You could also try uninstalling or re-installing, however I suspect that the real reason is reason 1, and no solution short of removal will solve your issue.
It is also worth noting that todays software is incredibly complex, often made up of literally millions of lines of code. There is not such thing as perfect code, and the occasional crash it to be expected. If you put a little effort into looking at the situations where these crashes arise, you will often find that there is a cause. Knowing this will at least allow you to avoid these situations in the future, even if it isn't a fix. NeroVision does not handle (amongst many other things) VBR MP3 audio very well. While usually the result is audio sync problems, some versions are known to crash when trying to process it. Look for common threads in the type of video you are encoding when things do crash. Of course, if it crashes all the time, there isn't much you can do.Read my blog here.
Well it worked before on the same sort of files, but then didn't. I found that you have to use Burn-at-once to fix this sort of thing...man why can't they make things simple.
Nero Vision xtra
By salohcin69 in forum Latest Video NewsReplies: 0Last Post: 20th Apr 2010, 05:30 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 16:11 -
Nero Vision 5 Help
By luckyboym in forum Authoring (DVD)Replies: 1Last Post: 25th Feb 2008, 00:47 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 11:10 -
Nero Vision 5
By marioval in forum Authoring (DVD)Replies: 0Last Post: 11th Oct 2007, 13:45
