Hey guys, I have some tv show clips in mpeg4 and I'm trying to simply edit parts of them out, but whenever I re-encode with virtualdub the audio is always out of sync. Is that because I am encoding from mpeg4 to mpeg4? What do I need to be aware of when re-encoding like this, and what might be causing the sync problems?
No, i'ts probably because of vbr mp3 audio.
Try instead virtualdubmod and select no when it asks if you want to rewrite the header. Or convert the audio to uncompressed wav and use it as source and then edit. -
Good idea, I knew that VBR audio was trouble....
Hey should I re-encode the audio or use direct stream copy, or does it matter as far as sync issues go??
Which software to edit dreambox mpeg4 ts?
By manutd in forum EditingReplies: 11Last Post: 3rd Jan 2012, 09:00 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
Avidemux edit leads to out of sync audio..
By Jmart285 in forum Newbie / General discussionsReplies: 18Last Post: 18th May 2011, 15:35 -
What is the best way to edit MPEG4 files
By Paul W in forum Newbie / General discussionsReplies: 8Last Post: 1st Apr 2008, 12:32 -
edit w/o recompressing mpeg4 and wmv
By mrready in forum EditingReplies: 3Last Post: 29th Jan 2008, 09:56
