Hello!
I need advise on how to network the cpu and ram of two computers together because my ram is too small for an operation on a buggy software, it might solve the problem for that case...
thanks for any advice! X
That I know of you can not share memory or the cpu via a network. You can share printers, devices and hard drives........ Good Luck
Take the RAM from one PC and add it to the other. No way to share the RAM as you intend, at least with any conventional software.
Also no way to share the cpu, very, very few programs are set up for distributed processing and none that the average user is likely to own. -
From what it sounds like is that you want a cluster. But from what you are using it for it sounds like it wont work. The program that you are using is most likely not programmed for it.
Hunting, sure i'll go hunting. When is cow season?
Ram recommendation for amd cpu & biostar mobo combo?
By Stealth3si in forum ComputerReplies: 27Last Post: 11th Feb 2012, 12:05 -
Salvaging CPU, RAM and Hard Disk from Laptop
By pchan in forum ComputerReplies: 6Last Post: 24th Nov 2011, 19:06 -
Config new PC - importance of CPU speed, L3 cache, RAM?
By OldAmateur in forum ComputerReplies: 19Last Post: 29th Jan 2010, 13:47 -
premiere pro+mainconcept hd: best hardware setup (hdraid, cpu, ram)?
By razzta2001 in forum EditingReplies: 9Last Post: 8th Oct 2008, 07:54 -
Matching CPU/Motherboard FSB to RAM Speed?
By rkr1958 in forum ComputerReplies: 2Last Post: 24th Jul 2007, 21:25
