Hi
Is it possible to convert video to some basic format for which I or somebody else don't need codecs or anything similar.
Results 1 to 19 of 19
On Windows, you can create the videos as uncompressed AVI files - each frame will be a bitmap. The file will be very, very big!
John Miller -
What exactly do you want to do?Originally Posted by ErollorD"Art is making something out of nothing and selling it." - Frank Zappa
I'm creating this presentation cd and I must include videos in it. I inserted normal avi and everything works on my home pc where I have codecs installed. But if I test it somewhere else, on some other pc which don't have codecs I get error. So I must include video for which we don't need codecs...
Will it always be on a Windows PC that the CD is used?
If so, there are some codecs that all Windows PCs will have.
If it will be used on other operating systems, then you need to find a common format. But, if you are using AVI, that will limit the options.
Also, you can always put the codec on the CD and, if it is missing on the user's PC, it can be installed.John Miller -
Please confirm - are you inserting videos in Powerpoint?Originally Posted by ErollorDJohn Miller
all windows from win98 on and I believe win95 have mpg1 support built-in. I have no knowledge concerning Apple or Linux units. MPG1 will represent the best compression available without installing any additional software. Note that you are free to exceed DVD specs for bitrate and resolution.
I think this will mostly be used on windows, but I can't add an option for installation of codecs because some people find this too complicated.
No, it's not powerpoint, it's some other program, called autorun pro...
ps: How can I create uncompressed AVI? -
virtualdub saves as uncompressed avi by default, however you won't get much video on a CD.
FWIW, going back quite some years, CD based video has traditionally been encoded as either mpeg1, or as some form of quicktime, with the quicktime installer (usually played back through a director based application). Mpeg1 is a much better option than uncompressed.
Also, uncompressed is likely not going to play back smoothly on older machines, especially from a CD.Read my blog here.
Use MPEG1... you can use higher resolution with better quality with WMV but that will only have high compatibility with windows machines. WMV will play on just about any windows machine, the only thing they need is the 6.4 player or later. It's been a while but I believe it was installed even with Win98 out of the box. Possibly even Win95... Whatever the case you will be hard pressed to find aWindows machine that won't play it, if you really want to make sure about WMV comaptibilty encode it using an older version.
hi, one more thing. Is there any similar program to this? free or comercial..
If you exported "DVD" format, that's wrong. DVD's main format is MPEG2 (though it supports a certain limited set of MPEG1 streams).
I've got Vegas6 (assuming V7 is very similar in GUI). Choose [Render], Drop down allows MPEG1 and MPEG2 (as well as MANY others). Choose MPEG1 (VCD-NTSC) or something similar. It'll work fine for what you want (I've done that many times).
Very Basic--> What format to work with Final Cut with my HD cam.
By Mcjuicypants in forum EditingReplies: 0Last Post: 5th Mar 2011, 20:55 -
Need Basic Video Editing Software - PC
By Bascotie in forum Newbie / General discussionsReplies: 7Last Post: 12th Feb 2011, 07:15 -
Basic Video Encoding Question
By crosen in forum Newbie / General discussionsReplies: 9Last Post: 24th Oct 2009, 19:48 -
Need your help on some very basic video questions
By Booklet in forum Newbie / General discussionsReplies: 3Last Post: 6th Oct 2009, 12:12 -
By Dan K in forum Newbie / General discussionsReplies: 17Last Post: 2nd Jan 2009, 16:59
