    Jan 2007
    Hello Everyone,
    I am currently using DVD-Lab Pro to create my FIRST DVD. I have followed the steps that is shown in tutorial "http://www.dvd-replica.com/dvdlabpro/part1-2.php". Unfortunatly, when I get to the end and try to Compile DVD I get an Error "Pre verification fails. Process abort ! - 1998" and ABORT the process!
    Can anyone tell me what I am doing wrong? Thank you for your help and have a great day.
    Khoramdin...
    Ps. This is what I get in the compile window:
    *** DVD Aa2 Pro Verification Log ***
    1 - 18 - 2007 -- 10:59:24
    * VMG Verification *
    Number of VTS - 1
    Number of Menus: 1
    Menu 01 - Type - Dummy
    Number of imported VTS: 0
    * VTS Verification *
    <<< VTS Number 1 >>>
    Number of Titles: 2
    Title 01 - Type - ES or PES
    Segment 1, Video File C:\Documents and Settings\Miyaoo\Desktop\DVD TEST\Limerick_720x480_MPEG2_q9.mpv
    Frame Size: 0 X 0
    Frame Rate 0 [1--23.976, 2--24, 4--29.97, 3--25, 5--30]
    Wrong video frame rate
    Aspect Ratio: 0 [43--4:3, 169--16:9]
    Video aspect ratio is neither 4:3 nor 16:9
    MPEG Video Type: 1 [1--MPEG 1, 2--MPEG 2]
    Chroma: 1 [1--4:2:0, 2--4:2:2, 3--4:4:4]
    GOP 1, size - 17840
    GOP 2, size - 18608
    GOP 3, size - 18608
    Segment 1, Audio File C:\Documents and Settings\Miyaoo\Desktop\DVD TEST\Limerick_720x480_MPEG2_q9.mpv
    Audio type: MPEG, Channel: 2, Sampling: 48000, Bitrate: 192000
    Title 02 - Type - ES or PES
    Segment 1, Video File C:\Documents and Settings\Miyaoo\Desktop\DVD TEST\WhatBox_MPEG2_720x480_q5.mpv
    Frame Size: 0 X 0
    GOP 1, size - 386284
    GOP 2, size - 37976
    GOP 3, size - 392460
    Segment 1, Audio File C:\Documents and Settings\Miyaoo\Desktop\DVD TEST\WhatBox_MPEG2_720x480_q5.mpv
    Number of Menus: 1
    * Status Messages *
    Something is wrong with mpv video files. How did you make them?
    Jan 2007
    Hello Baldrick,
    Thanx for the reply. I had downloaded Two Movie Files (mpeg) and when I imported the files in the Assets Inviroment of the DVD-LAB Pro, it converted them into mpv.
    I should say that I don't see the converted files (mpv) in my folder but they appear in the assets window. The only movie files that I can see is the original MPEG files.
    Thanx for taking the time to help me out.
    Cheers,
    Khoramdin
    Identify the video details and audio of the mpg files with mediainfo or latest gspot. Are they mpeg2? what frame rate and video resolution?
    You can also try demultiplex/split the video and audio from the mpg using some other tool like batchdemux or tmpgenc(file->mpeg tools) and then import the streams in dvd-lab and see if it works better.
    Jan 2007
    Hello Baldrink,
    Thank you very much for your suggestion. As you suggested I used "TMPGEnc 4.0 XPress" and Demultiplex the Video and Audio and it worked just fine.
    Thanx very much again.
    Khoramdin
    Ps. Is there any way I can check to see the DVD created works fine before buring it on a DVD?
