I heard that it's possible to get HD channels on my computer. How does that work?
At the moment I have a very old TV Tuner card, with just your basic RCA input. Is it a similar thing to that?
How does it work getting access to the channels? Do I still need to sign up with some kind of Cable company or Dish?
What kind of hardware do I need? Does anybody have any reccommendations about the best way to watch HD on my computer?
Thanks!
Have you done a search at http://www.videohelp.com ? They're a pretty good site for that kind of info.
While you're at it, search the web for DVICO.
They have such products.Whatever doesn't kill me, merely ticks me off. (Never again a Sony consumer.) -
First step, put your address into http://www.antennaweb.org/ to see what channels are available at what distance, power and direction. That dictates your antenna needs. Then get a HD (DTV) tuner card or a digital television.
http://www.kiva.org/about -
I'm using the My HDTV MDP-130 card. It works pretty well with Windows. I connected an antenna to it and I was getting excellent OTA (Over The Air) reception from Fox and a few other channels, but eventually OTA reception got worse and worse and I finally had to break down and use a cable box as OTA for me became bad pretty much all the time.
The MDP-130 should NOT be used for recording analog TV. I recommend a real analog TV card like you have for that. -
if you live far away from the city you going to need a big outdoor antenna like a ChannelMaster 4228 with a ChannelMaster 7777 preamplifier.
more info and help
http://www.avsforum.com/avs-vb/forumdisplay.php?f=45
SKY hdTV > Hauppauge HD PVR > Computer
By JBD007 in forum DVB / IPTVReplies: 2Last Post: 5th Sep 2011, 08:05 -
Computer to HDTV using HDMI
By rajtp in forum DVB / IPTVReplies: 6Last Post: 17th May 2011, 18:30 -
How can I connect my HDTV to my computer as a secondary monitor?
By cucuzza in forum DVB / IPTVReplies: 6Last Post: 15th Feb 2011, 12:06 -
Problem using HDTV for computer screen
By beavs in forum DVB / IPTVReplies: 34Last Post: 17th Sep 2008, 02:07 -
computer to HDTV
By mrspcy in forum Newbie / General discussionsReplies: 10Last Post: 15th May 2007, 17:11
