    Jan 2007
    I am a very, very, very new newbie. I just recently learned to spell WMV and MPEG. Please have patience. My question regards converting WMV to MPEG. After conversion, some MPEG files will only show the video portion for a few seconds and then freeze. The audio continues until the end of the file, but the video will never proceed past the point where it stopped. Sometimes, I download MPEG files that already contain that symptom. Any help and guidance would be greatly appreciated.
    thank you
    gggh12002
    Hi and welcome to our forum!
    what software are you using?
    Jan 2007
    Thank you. Listing my software would help. You can really tell I'm new and don't know what I'm doing.
    I use a converter I purchased from Boilsoft, version 3.6.1. I also sometimes use a converter called MPEG4 (I'm at work at this time and can't remember who wrote this one). I use Windows Media player as my viewer.
    Love your Avatar. I'm a huge BlackAdder Fan.
    thanks
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    wmv is one of the worst sources you can work with, imo.
    For the simple approach, go for Super.
    Otherwise, Use AviSynth, frame serve to some encoder like hcenc
    /Mats
  5. Member nbarzgar's Avatar
    Sep 2004
    Austria
    Converting wmv to mpeg is one of the most trying tasks you can set yourself, imo. I've been around video-capturing, -conversion and playback for over 4 years, but getting working mpeg-1/-2-files from wmv seems to be near impossible in a single step/application.
    You may want to try WinAvi Video Converter, it produces files that are in synch, the main problem usually. The drawback: very often the bitrate is way beyond any specs for mpeg2/DVD-files. It is not possible to control that inside the app. So playback on a standalone may be faulty.
    Other encoders - Canopus, CCE or Mainconcept - produce great quality but in case of wmv-to-mpeg conversion the resulting files are out of synch in 9 cases out of 10.
    The 'short' step-by-step suggestion:
    1. Use one of the mentioned encoders (or TMPGenc, of course, also great quality, just rather slooow) to encode to mpeg2- (or mpeg-1 for VCD) elementary video. Follow specs on this side (upper left-hand corner for specs + guide-section)
    2. Extract the audio with Virtualdub-MPEG2 (still supports wmv/asf-format) to .wav.
    3. Use Audacity or Goldwave to resample the audio to 48MHz.
    4. Follow this guide to get audio and video in synch: https://forum.videohelp.com/viewtopic.php?t=140540 and refer to this post inside the thread for instructions on Goldwave: https://forum.videohelp.com/viewtopic.php?p=441713#441713
    5. Author with TMPGEnc DVD Author or similar (VCDEasy, for VCD)
    Any help or guidance for the single steps are to be found in the tools-section for the respective tool, clicking right-hand corner of tool-description, where it says "Guides".
    Note: should you have problems playing back mpeg2-files in general, first solve those, use GSpot to load the file and watch out for the - possibly - missing codec. Stay away from codec-packs!! Downloading the respective codec as needed is far better, as your system will not be cluttered and ultimately put out of work...
    Good luck!! 8)
