  1. Member AlecWest's Avatar
    Mar 2002
    Vader, WA, USA
    I'm on the verge of getting an Epson RX580 printer. And, on their website, this is the link they give for the User Guide:
    http://files.support.epson.com/htmldocs/rx58__/rx58__ug/index.htm
    Using MSIE 7 and Firefox 1.5, I get the same result - a 404 error. But, when I put an "l" character at the end of the URL string:
    http://files.support.epson.com/htmldocs/rx58__/rx58__ug/index.html
    I'm instantly transferred to a third webpage:
    http://files.support.epson.com/htmldocs/rx58__/rx58__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
    and the User Guide magically appears. The problem? I called up Epson's customer support line and decided to be a good neighbor - telling them about the erroneous link. But, when the Epson rep clicked on the first link, the User Guide DID come up. So, she thinks I'm coming from Venus .
    Anyhoo, I'd like a few other people to try that first link only and tell me if they get the User Guide or a 404 error. If enough people get a 404 error, I'll send them a little email suggesting what I suggested to the rep ... that she's on an Epson server that probably directs her to the right page while ordinary Joes like me (on the web) go nowhere - unless they "experiment" like I did to come up with the right page.
    Thanks in advance, whatever you see.
    P.S. If the User Guide does come up for you at the first link, what possible explanation could there be for me NOT seeing it?
  2. The root of all evil träskmannen's Avatar
    May 2005
    Belgium
    I got the same result as you - a 404 from the first link while the one with the added "l" redirected me to the user guide.
    In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move.
  3. Aging Slowly Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    Same Result here as well..
  4. Member AlecWest's Avatar
    Mar 2002
    Vader, WA, USA
    Thanks. I suspect I'm right ... that the Epson rep is "hardwired" to the guide on her LAN. Consequently, she sees no problem. And, when people like me call up to mention the problem, our calls are chalked up as being silly.
    Would like to see more people do the experiment, though, so I can give them a "consensus" email. Again, thanks.
  5. Member Conquest10's Avatar
    Chicago, IL
    404 Not Found for me.
    His name was MackemX
  6. Member Webster's Avatar
    same here.
    1f U c4n r34d 7h1s, U r34lly n33d 2 g3t l41d!!!
  8. Member Webster's Avatar
    404 from home too.....
