I have just bought a Sony CRX200E cd burner that can do double density CD's.
Has anyone managed to burn a vcd that was double density, and if so did it play on a stand alone DVD player, and thirdly, how did you burn it?
I have tried in Nero to do a 1.1Gb vcd, but it says its too big (yeah, I know) but there is no option to do a DD-CDR vcd (or to be specific x-vcd).
Sorry if this question has been asked before, but with the search page doen there is no way of checking.
Cheers
Mikee
Senior Designer of things -
Sorry, but DD VCDs are impossible.
Unless I'm mistaken, the way that your double density CDs work is that the data can only be burnt in a form of packet writing. Thus, you can only use if for data but nothing else.
As it doesn't burn in the conventional way, you can't use double density CDs to make audio CDs or VCDs.
Regards.Michael Tam
w: Morsels of Evidence -
Oh Well, thought it was too good to be true, but it will do until dvd-r are truely affordable
Mikee
Verbatim 94554 CDR vs. 94712 CDR. What's the difference?
By Puppets86 in forum MediaReplies: 12Last Post: 3rd Oct 2010, 16:31 -
AVI to DVD - Only 3Gb size
By Mutenroy in forum ffmpegX general discussionReplies: 3Last Post: 28th Mar 2008, 23:39 -
question about how to cut 1 minute out of 4.3GB DVD (no menus)
By jimdagys in forum EditingReplies: 20Last Post: 18th Nov 2007, 01:31 -
1.3GB DVD Help Camcorder
By Mark V in forum MacReplies: 8Last Post: 18th Sep 2007, 11:24 -
Converting AVI to DVD - Only 3Gb
By Mutenroy in forum ffmpegX general discussionReplies: 4Last Post: 2nd Aug 2007, 17:21
