im looking for programs that does the job real quick and still produces decent quality.. any suggestions?
Results 1 to 13 of 13
Nero is very fast if you have an .mpg file you're writing and the quality is among the best
convertxtodvd is pretty fast. or cce basic together with an all-in-one tool like thefilmmachine.
Another vote for ConvertXtoDVD . If speed is your #1 criteria, that is the one.
If your source is downloaded avi files of the usual quality then ConvertXtoDVD is all you need. The quality is already relatively low, so you don't need the best quality encoder in the world.
If you are talking about your home movies in DV format then it is a different proposition. Then you should be considering CCE Basic (fast good quality), ProCoder (a little slower, very good quality) or even HCenc (free, slower again, good quality)Read my blog here.
I think all these suggestions stink.
"real quick and still produces decent quality" does not exist. Learn some patience, otherwise it'll just look like crap. CinemaCraft Encoder Basic should be fairly speedy.
You do realize it's not the software, it's your CPU, that determines how fast video is encoded?Want my help? Ask here! (not via PM!)
All hail the blue guyOriginally Posted by lordsmurf
wait a second, guns1inger already suggested CCE -- so does that mean your suggestion also stinksOriginally Posted by lordsmurf
That is absurd -- it would mean that ALL software will encode at the same rate given the same CPUOriginally Posted by lordsmurf
I think it's a combination of BOTH Software/encoder and CPU
Regards,
George -
It's not only absurd, it's demonstrably untrue simply by testing several different encoders on the same piece of test footage.Originally Posted by GeorgeW
Whats the fastest video encoder?
By groggit in forum Video ConversionReplies: 25Last Post: 14th May 2013, 12:14 -
which is the fastest encoder no matter output format
By gyzel01 in forum Video ConversionReplies: 30Last Post: 17th Nov 2011, 05:20 -
Whats the fastest single system setup for encoding right now?
By x2x3x2 in forum Video ConversionReplies: 0Last Post: 15th Aug 2011, 05:08 -
whats the fastest video converter?
By ADDlCTlON in forum Video ConversionReplies: 4Last Post: 10th Mar 2010, 16:29 -
Whats the fastest FLV encoder?
By last_registered_user in forum Video ConversionReplies: 0Last Post: 9th Sep 2009, 23:17
