hmmmm. I never really seen this before. I'm using Adobe Premiere 1.5 pro with Magic Bullet to put on at the end of my final cut. I created a six minute video with a complex timeline. Now when I export it to MS DV and then I watch it on EVERY media player there is to see if it was the media that might of been causing the problem and its not the media. Anyways the problem I'm having is occuring a Minute into the movie. It seems that the opening clip starts off in slow motion for about 3 seconds. then goes to its current speed at 100%.
I never change anything on this clip. The only thing I did to it was added the Magic Bullet filter on it at the end of my final cut. Even when I played it on the DVD Player, it did the same thing. It's weird. I even went back and Cleared all the key frams out of that certain clip; and i'm having the same problem. What could be causing this. It happen TWICE in the same timeline. As for the second time, I just deleted it because I did it need it for the story. But as for the first, I need it.
suggestions?
Murray
I'm a bit confused, but regardless.....
What i do usually, is create a copy on the track above, and shorten that track by only how much you want filtered...
Therefore, you don't have to render out the entire timeline, regardless of when you actually wanna keyframe..
How's about a snaphot of the project??
How can I get the smoothest slow motion out of a clip?
By 123erik in forum EditingReplies: 15Last Post: 14th Jun 2011, 15:15 -
How can I edit a montion menu of DVD?
By schtroumpfs in forum Authoring (DVD)Replies: 3Last Post: 9th May 2009, 05:57 -
How edit a clip to play @ 1/2 speed (slow motion) in Vegas 8 plt.
By Jensen in forum EditingReplies: 7Last Post: 12th Feb 2008, 12:23 -
How Do I Put A Custom, Created Slow Motion Clip Back In? (Virtualdub)
By WishMaker in forum EditingReplies: 8Last Post: 24th Oct 2007, 11:14 -
having trouble opening an avi clip from a Canon ELPH SD600
By Webster in forum Video ConversionReplies: 7Last Post: 12th Aug 2007, 18:06
