Hello all... I need a little help
I have been using Super DVD Creator 9.25 to convert video files and then burn those converted files to DVD with simple menus. I have had little to no problem with files smaller than 1 hour in length. But anything over 1 hour long I start to get audio sync problems.
The input files very in type and size, my system is a Core 2 E6600 w/2GB RAM, my writer is a Plextor PX-716a. When I make these DVD's the input files and output file are on different drives and controllers and my SWAP file is on another drive but on the same controller as my input file drive.
Dose anyone know what would be causing the problem... is it software are hardware? If it is a software issue, can someone suggest a better one?
Audio sync issues which usually occur when converting from various formats to mpeg2, are often the result of two things, corrupt files or the conversion software.
If your input files are free of errors and play normally, then the problem is occuring in the conversion stage. The easy way with decent quality, would be a tool such as Convertx2DVD. You could also just as easily convert the files to mpeg2 yourself and then author.Google is your Friend -
sync problem is not a simple question ,even your DVD Player will cause the sync problem .
I did not meet it ,maybe you need to send a email to your software publisher .
if your DVD become no sync suddenly , you can pause the DVD playing and then go on play the DVD ,it will be ok.
How To Cut MKV Without Audio/Video Sync Problems
By Eva-Unit01 in forum Video ConversionReplies: 12Last Post: 2nd Mar 2011, 08:11 -
Video Audio Sync Problems
By Johnnysh in forum DVD RippingReplies: 11Last Post: 26th Jan 2011, 01:47 -
Sync problems after merging mkv video with mp3 audio
By billman1234 in forum Video ConversionReplies: 5Last Post: 29th Jun 2010, 15:00 -
Audio sync problems when re-coding captured video. Any Solutions?
By uart in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 17:34 -
Trying to sync audio with edited video, problems with encode....
By Jensen in forum EditingReplies: 1Last Post: 5th Jan 2008, 08:20
