I understand there is a frame advance feature with powerdvd. However I can't find it. Also I read somewhere that you can screen capture using powerdvd. I am very confused here. I would like to capture a few frames to make small avatar type stuff. Any help would be great.
Thanks in advance.
If you can't get that to work, you can also use Media Player Classic. Pause the playback at the image you want, then go FILE -> SAVE IMAGE. You can also use the arrow keys to advance and go back individual frames.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
Here it is on mine. It's the Pause and Advance-a-frame-at-a-time button.
The screen capture is the little camera. -
that brings up another question I have. When I hit the C key for capture. Where does it capture it to? The clipboard? Can't I just use the printscreen key for that? Thanks
I'm pretty sure that the t key will advance one frame at a time.
To find where your pictures are being saved, click on the tools icon. Also, if hardware acceleration is enable, I don't think the screen capture will work, so you'll have to uncheck that option. There are options there as to what quality you want, naming, directory to save in, etc.
The printscreen, if it works, will capture everything you seen on your monitor, not just the video. -
You have to go into the programs configuration to set where you want the files to go. You can also set the size of the pict.
PowerDVD
By BobbyScot in forum Software PlayingReplies: 1Last Post: 28th Aug 2009, 13:38 -
can't see anything on powerdvd
By Remyisme in forum Newbie / General discussionsReplies: 2Last Post: 10th Mar 2009, 12:18 -
PowerDVD 6.5 HD playback
By wulf109 in forum Software PlayingReplies: 1Last Post: 22nd Jan 2009, 08:05 -
Powerdvd keeps on crashing...
By uehara in forum Newbie / General discussionsReplies: 1Last Post: 27th Jun 2008, 20:58 -
WinDVD 9 vs. PowerDVD 8?
By Vrex in forum Software PlayingReplies: 0Last Post: 7th Apr 2008, 22:54
