Hello,
This is my first post on this forum
I have some VOB files with no IFOs, BUPs or menus. Now I want to create DVD using these VOB files but Nero burning software giving error as there no IFO and BUP files. I need help to create IFOs and BUPs with some basic menu functionality. I have tried IFO/BUP creation with IFOEDIT but it messed up with chapter sequences though VOB files are renamed correctly.
Thanks in advance![]()
Thanks for replying
Originally Posted by AlanHK
Also I need only basic menu - so that it's easy to play each VOB (or movie) file in DVD player using the menu. -
Originally Posted by amit
If you're short of space, delete the VOBs after you demux and test them
How can you create a menu if you don't reauthor?
Authoring:
Very simple, one title, no menu: Rejig.
With menu: you need something more complex, I use GuiforDVDAuthor. -
Thanks in advance -
Anyway, the way GuiforDVDauthor works is to create bunch of batch files calling the DVDauthor utilities.
The first is to mux, eg:
echo (shrink and) mux video and audio files
"P:\GUI4dvdauthor\mplex.exe" -f 8 -o "q:\DVD\Temp\sja-101.mpg" "s:\mpg\sja-101.m2v" "s:\mpg\sja-101.ac3"
It shouldn't be hard to convert that to a shell script. But I'm sure there are boards devoted to doing this on Linux, where you can get more specific help.
Combining VOB files from different sources to create a new compilation
By bluesmanuk in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2010, 14:24 -
Can I create an .IFO file from .VOB files?
By Madcap in forum DVD RippingReplies: 7Last Post: 15th Aug 2010, 14:57 -
Help me create an .iso file from .vob dvd files!!
By SlyOne in forum DVD RippingReplies: 2Last Post: 15th Aug 2010, 09:25 -
How do I create VIDEO_TS IFO from VOB files
By stockton209 in forum DVD RippingReplies: 2Last Post: 8th Jan 2010, 03:07 -
create menu for 2 movies with several vob files with guifordvdauthor
By aruwin in forum Authoring (DVD)Replies: 1Last Post: 30th Dec 2007, 05:22
