hello im kinda new to this converting i was curious how to take 3 mpeg movies and convert them to burn on a blank DVD disc and watch it on my DVD player any help would be appreciated or point me in a direction of understanding how to go about it please thank you
Open each mpeg file using g-spot 2.60 beta or later. Note the resolution, framerate and audio type for each mpeg file.
Compare these to those described in the section marked What is DVD (top left corner of this page).
If they match, use a DVD authoring tool to create a DVD structure, and burn to a blank DVD with imgburn 2. GUIForDVDAuthor or DVDStyler are free, Tmpgenc DVD Author is cheap and has a 30 day demo.
If they do not match, then you will have to convert them. There are plenty of guides to your left or in the guides forum on how to do this, however if you want a simple approach, look at ConvertXtoDVD, which will encode and author the files ready for burning.Read my blog here.
Problem converting H264(mkv), keeps crashing while converting.
By weedelf in forum Video ConversionReplies: 4Last Post: 9th Apr 2009, 23:56 -
Converting/examining my video files and converting to have less pixelated?
By SimpleSimon in forum Video ConversionReplies: 51Last Post: 28th Aug 2008, 23:33 -
Converting songs purchased on itunes and converting to mp3
By maroonx in forum AudioReplies: 1Last Post: 23rd Jan 2008, 00:17
