Dear... IPA 99% would not damage the rubber or plastic then... I just often hear people say "be careful" but don't provide methods... do they mean I shouldn't touch the rubbers and plastics with the alcohol or just don't get them drenched.Originally Posted by Constant Gardener
Results 31 to 38 of 38
You can use a lent free cloth. Dampen it with the rubbing alcohol and wipe things off gently. Very carefully.
What about my kinyo 2 way rewinder it has tape cleaner button... should I use that...? are there other method to clean tapes? after all... most of my tapes are dirty... u know I never ever worry about cleaning heads until recently I often used tape cleaners but now I realized that is never enough.Originally Posted by Constant Gardener
@deuce8pro
What if I use my towels 70% isopropyl to clean the paths will that be sufficient alcohol not to damage the rubber or plastic at the same time cleaning them... instead of using foam swabs with 99% IPA. -
"isopropyl" is "isopropanol". The correct name is propan-2-ol.Originally Posted by CCEncoder
In practical terms, it makes no difference whether you use 95% or 99.9999999%.Originally Posted by CCEncoder
Well, my personal preference is methanol - it evaporates faster than ethanol.Originally Posted by CCEncoder
I've always used methanol for cleaning critical laser optics in a laboratory situation.
The recommendation for the 99% isopropyl alcohol is perfectly OK.
What's important is the technique. Consider getting some proper lens tissues. I usually wrap one carefully around the end of a pair of tweezers or a wooden stick to make a swab.John Miller -
Is the lens tissue same material as chamois? can I use cottom swabs sticks instead of tweezers?Originally Posted by JohnnyMalaria
No. Chamois is cow hide (leather).Originally Posted by CCEncoder
Lens tissue is a kind of paper that has no lint.
e.g: http://www.pecaproducts.com/tissue.htm
You should be able to buy some at a local photographic supply store.
Yes.Originally Posted by CCEncoderJohn Miller -
Technically. For some uses. But for your use it won't make any difference. Save your moneyOriginally Posted by CCEncoder
"Is this Isopropyl 99% a good buy? "
I buy denatured alcohol at Ace. Its about $4 qt.
Best way to clean VCR heads
By Theresa in forum RestorationReplies: 67Last Post: 18th Sep 2023, 19:14 -
Best PAL VCR player with 6-heads - multi region/system would be preferred
By jbloggs in forum DVD & Blu-ray RecordersReplies: 7Last Post: 16th Mar 2012, 16:20 -
Fedron to clean the inside of a VCR?
By Fryster in forum RestorationReplies: 9Last Post: 16th Dec 2009, 12:51 -
Aligning VCR Heads?
By frozentax in forum RestorationReplies: 13Last Post: 3rd Apr 2009, 20:35 -
old VHS tape making vcr heads dirty
By abbymat in forum RestorationReplies: 7Last Post: 16th Aug 2007, 07:33
