I watched a VCD movie and was impressed about the quality. It was not a commercial disk. Also, a bug in my standalone DVD player was hardly noticable. I would like to know which encoder was used to create this movie and all the settings necessary.
Which program can tell me the encoder that was used and the settings, e.g.: bitrate, VBV buffer, GOP structure, Quantize matrix.
Maybe you guessed it by now, I use TMPGEnc.
bitrate and VBV buffer will tell you Bitrate Viewer. If you have a full version, it will tell you the GOP structure as well. Otherwise use ReMPEG to see the GOP structure of each GOP.
.... i was reading this.. but what is actualy a GOB..
i know TMPGenc also uses this, it has a tab called "GOB"... -
some MPEG basics
http://bmrc.berkeley.edu/frame/research/mpeg/mpeg_overview.html
Any software to rename file based on video properties? good question!
By thomseye in forum Newbie / General discussionsReplies: 10Last Post: 18th Oct 2012, 17:07 -
Remove text from file properties
By Pegsitron in forum Newbie / General discussionsReplies: 1Last Post: 2nd Aug 2010, 07:29 -
Change File Properties/Information for Video Files
By MrRedPants in forum EditingReplies: 5Last Post: 16th Jun 2010, 23:33 -
Mpeg2=>Mpeg1=>PowerPoint via TMPGEnc but weird DAR
By l-w-c in forum Video ConversionReplies: 1Last Post: 24th Jan 2010, 09:17 -
The Summary tab on a Windows XP video file Properties page is missing!
By tigerb in forum Newbie / General discussionsReplies: 1Last Post: 18th Oct 2008, 22:11
