    Dec 2006
    I've succeeded in ripping a DVD to mp4 format and putting it on my iPod. I now want to put one with subtitles on the iPod.
    I know that iPod doesn't support .srt subtitle files, so I guess that the subtitles must be merged with the video, somehow.
    Is it possible? How could this be done on a Mac (OS X)?
    Thanks,
    JJ
  2. Member terryj's Avatar
    N35°25.24068, W097°34.204
    Several ways, depending upon your level of expertise from
    easiest, to hardest.
    Play file in VLC, capture in Snapz Pro with Subtitles on (easiest)
    ffmpegx merge video with SRT file to hard code subs ( not easy)
    Quicktime Pro hard embeddment of Sub Text file (hardest)
    take your pick.
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
  3. Member terryj's Avatar
    Seriban, old friend, if it works as good as the "pro" does,
    then yup you got me beat. Tutorial for Handbrake
    now if it would just do mkv files in a similar fashion.....!
    Urban Mac User
  4. Originally Posted by terryj
    Well, it should, since its a striped down "pro" version made just for iPod encodings..
    hehehehehe...Yes...Neverending story with mkv files...
