Results 1 to 9 of 9
    Jan 2007
    Canada
    Hi, I'm having troubles with Nero Vision in making slideshows, where would be a good spot to post it? and how could I post a screenshot of it to help make it easier to understand the dialog I keep getting? Thank you
  2. Member zoobie's Avatar
    Feb 2005
    Florida
    Try posting in DVD Authoring
    Press "print screen" button on your keyboard which takes a snapshot of your screen
    Open your image editor, paste, then edit and save.
    When you post, there's an 'upload image' option at the bottom of the post page.
    PS - Nero isn't recommended here because of all the postings of problems using it. However, it doesn't mean you can't receive help with it.
  3. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Please try to find a more descriptive subject. Major newbie here and have a couple of q's doesn't say much.
    I've changed it for you, but you may change it again by editing your original post.
    From the rules:
    Try to choose a subject that describes your topic.
    Please do not use topic subjects like Help me!!! or Problems.
    /Mats
    Jan 2007
    Canada
    At work right now so I can't post the screen shot but thank you zoobie for your help. I will explain my problem.
    When I open up my slidshow and I click browse it opens up a dialog box that says "Open" and has a couple of other tabs called Search and I can't remember what else. I didn't used to get this before but I was playing around with it a few days ago and when I was trying to get music to go along with my slideshow I did something and now can't even open up the browse without getting this darn dialog box. Really driving me crazy.
    Oh and thanx to the mod for fixing my title up
    Jan 2007
    Canada
    Oh, zoobie, what's an image editor?
  6. Member MysticE's Avatar
    Nov 2003
    Not a very helpful description. If all was working good before maybe an uninstall, reinstall will set things right.
    Jan 2007
    Canada
    Done the uninstall reinstall thing, I cleaned everything out too with a Nero online cleaner and then reinstalled it and nothing
  8. Member zoobie's Avatar
    Feb 2005
    Florida
    I've always considered uninstalling/reinstalling the last resort. Try in that authoring forum but be very descriptive and tell them everything that's happening...not just "nothing".
    PS - An image editor is what eveyone uses to adjust digital pictures. There are free ones and paid. Just Google for any term you don't understand and read the glossary here. You'll be very glad you did!
  9. Member MysticE's Avatar
    Nov 2003
    Originally Posted by zoobie
    I've always considered uninstalling/reinstalling the last resort...
    Hmm... I always consider that the first thing to try.
