I've downloaded 6 avi files, bootlegs of a music show. The audio sucks, you can barely hear the singers over the cheering of the crowd. How can I edit the audio so that the sound is better? If I need to join the videos, how can I do that? How do I create an SVCD out of the edited vid with a menu to select each song and a chapter per song?
1. Unless you're a bit of a guru with seperating out certain range frequencies etc, I don't think you'll have much luck enhancing the audio too much.
2. Use an audio editor. Check the tools section.
3. https://www.videohelp.com/virtualdubedit.htm
4. search the guides under "convert avi to SVCD"If in doubt, Google it.
Need recommended software to edit videos and create a DVD
By OM2 in forum Newbie / General discussionsReplies: 4Last Post: 14th Feb 2011, 11:09 -
Create edit and display movie with 120 FPS
By uridavid in forum EditingReplies: 10Last Post: 20th Aug 2010, 10:54 -
By uridavid in forum Newbie / General discussionsReplies: 1Last Post: 20th Aug 2010, 06:41 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
How would I create an Audio DVD from my audio files from scratch???
By Hittz in forum AudioReplies: 6Last Post: 10th Jun 2007, 03:15
