i have these two avi files and i want to make it into one big avi file?
Can anyone help me with this or tell me a program to do this
Thanks in advance,
SaM*T
SaM*T
Hrmm... I'm not sure if you can do this with virtual dub or not, I'd have to look. I remember a long LONG time ago when I didn't know anything I use to use something called pec's power joiner, it was pretty simple and straight foward.
VirtualDub can do it - but both parts must be identical (frame size, frame rate, video bitrate, video codec, audio codec, audio bitrate). This restriction applies to all attempts at joining (without reencoding)
/Mats -
VirtualDub can do that. I use VD Mod most of the time. Open the first file, then append the second to it, save with Direct stream copy. Both files have to have exactly the same settings.
BTW, if you are planning to make a DVD from them, don't put them together, encode separately, then add both into your authoring program and let it do the 'joining'. That avoids a lot of sync problems.
EDIT: I guess I need to refresh more often. Thanks, /Mats
Out put from avi files
By santolina in forum EditingReplies: 4Last Post: 20th Sep 2009, 12:51 -
How do I take .avi or.mp4 files and put them on a video DVD?
By TripleH in forum Newbie / General discussionsReplies: 6Last Post: 5th Sep 2009, 11:05 -
Put many avi files onto DVD
By Airjrdn in forum Authoring (DVD)Replies: 8Last Post: 23rd Apr 2009, 23:45 -
Nero converting vob to avi,,,files way to big after????
By jcurrieirocz in forum Video ConversionReplies: 7Last Post: 17th Nov 2008, 20:41 -
How do I put AVI files onto a DVD as AVI files?
By dgarmaise in forum Authoring (DVD)Replies: 15Last Post: 17th Mar 2008, 21:32
