My DVD player won't play a VCD a CD disc,
I've downloaded TMPGEnc DVD Author, but my PC won't open the program because of the processer on the PC.
Are there any other free programs that can change the following?
change the audio to a 48Khz sampling rate as a VCD uses 44.1Khz, which is not DVD compliant.
Thanks in advance
Results 1 to 14 of 14
DVD-Lab Pro ?
/Mats -
If I understand the OP right, he/she's got a VCD that his/her player wont play, and want to author it as DVD. Right?
/Mats -
What is your problem exactly? You can't play ANY VCD at all or you can't play a specific VCD? If the latter, is this an Indian VCD by any chance? You should be aware that Indian VCDs are copy protected to prevent PCs from playing them. By the way, what kind of CPU do you have because unless it's a 486 or maybe an 8+ year old Pentium, Tmpgenc shouldn't care.
Use VCDgear to convert the *.DAT VCD file(s) on the VCD (look in the MPEGAV directory on the VCD disc) to *.MPG file(s) and then demux them. BeSweet (or BeSweet GUI which is easier to use) can then convert from 44.1 Khz to 48 Khz. Other audio editors can do this type of conversion too. -
The pc's about 9 1/2 years old, the VCD plays on my PC, but not on the DVD.
What is the make/model of the DVD player
Some early models would ONLY play DVD's (and originals at that)
That's from the time when DVD burners were around £800
and no-one had one
I have an old Sony and Panasonic, both of which will not play either VCD or SVCDDon't worry.......we'll be alright... -
Basic it is, but it says it plays vcds:
Manufacturer: Toshiba
DivX Playback: without DivX Playback
DVD Audio Playback: without DVD Audio Playback
DVD Player / Recorder: DVD Player
DVD+R Recording: No
DVD+RW Recording: No
DVD-R Recording: No
DVD-RAM Recording: No
DVD-RW Recording: No
Integrated VCR: without Integrated VCR
Memory Stick: No
MP3 Playback: without MP3 Playback
MP3 Recording: No
MPEG4 Recording: No
Multimedia Card: No
PCMCIA Interface: No
Photo CD Playback: without Photo CD Playback
Real Dolby: without Real Dolby
Show View: without Show View
Smart Media Card: No
Super Audio CD Playback: without Super Audio CD Playback
Super Video CD / Video CD Playback: Yes
Table / Portable: not Portable -
According to the sources i've checked, there should be no problem playing VCDs and SVCDs on your machine.
Unfortunately this means something more technical is at fault.
Check the VCD using Explorer or something similar, and post the list of folders it contains.
If any of the required folders is missing this may cause it to glitch on a standalone player where the PC may not be worried.
How did you come by this VCD - is it a self-created disc - what did you use to create/burn it etc
Please provide as much info as poss.Don't worry.......we'll be alright... -
Get the trial version of TMPGenc DVD author 1.5 or 1.6 and try it out. You just add the VCDs to it and it will convert the audio when you go to make the DVD.
Thanks for the followup info it was helpful.
First of all, yes, you need to demux with a different program than VCDGear. TMPGenc can do it. MPEGVCR can do it. There are probably freeware programs that can demux too, but I'm not sure about those.
I think I now know what your problem is. It appears from the original post that you are saying that the DVD player won't play VCDs or audio CDs. Is this right? If so, it means that the laser that plays CD discs (it's different from the laser used for DVDs) is broke. It's not worth repairing if that's the case and you should buy a new player.
At 9+ years old, I suppose your PC may be too old (or more exactly "underpowered in terms of CPU") to run TMPGenc.
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 16:32 -
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 12:55 -
Video from PC encoded and Burnt to VCD to Play on my DVD R Player
By dashas in forum Video ConversionReplies: 3Last Post: 16th Jul 2010, 21:15 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 19:32 -
GPX D1816SIL dvd player and I can not use it to play VCD disk.What should I
By nyankum in forum DVD & Blu-ray RecordersReplies: 2Last Post: 13th Jul 2008, 12:15
