Hi everyone,
I have a Philips SAA7134 PCI AV tuner installed, and when I put my coax cable in the RF IN, I can get all the channels that are on the cable. I can watch TV perfectly. When I put the coax first through my VCR and then to the PC, I can still watch all of my channels.
So, here's my problem: I want to record something from my VCR to my PC (I put a short cable straight from RF out on the VCR to RF IN on the tuner), but I can't get any video... When I scan for channels, he doesn't find anything (but I notice that he stops a bit at channel 74-75), so when I go to channel 74 I can hear the audio of the VCR perfectly...
The strange thing is: about a year ago I tried to do the same thing and everything worked perfectly... I had to do a reformat, but I installed the latest drivers (and TV channels are working perfectly), so I don't think that's the problem...
I've used Intervideo WinDVR3, Intervideo Home Theatre, K!TV and they all do the same thing: audio, but no video...
Any ideas?
Thanks in advance
Wonder if the program has the VTR option ? , then the vcr becomes the channel changer via remote ?
Of course the audio will affect the picture quality doing it this way via the rf ... but go right ahead .
If the option on the card is available , video to rca input , capture audio via the pc line-in ... you'll need an adapter or two , and maybe the rca cable's , long enough to go between the device's ... without tripping all over them and hanging yourself by accident .
You'll get a better picture this way .
Video Capture PCI / USB recommendation?
By harky in forum Capturing and VCRReplies: 0Last Post: 6th Mar 2012, 20:04 -
operating system advice / bt878 / saa7134 / hardware config
By jafvid in forum Capturing and VCRReplies: 16Last Post: 23rd Mar 2010, 18:46 -
getting new PC: use onboard video or PCI-e dedicated video card?
By alandla in forum Newbie / General discussionsReplies: 18Last Post: 27th Feb 2008, 11:13 -
Video Advantage PCI: Interlaced Video/No Live Audio Preview/Other Questions
By acid_burn in forum Capturing and VCRReplies: 2Last Post: 8th Feb 2008, 21:03 -
Problems with Pal-60 capture using ATI AIW 2006 PCI express Radion X1300
By DB83 in forum Capturing and VCRReplies: 2Last Post: 6th Aug 2007, 17:49
