I have a similar problem. I had been successfully reading and burning DVDs with two separate external USB DVD RW drives until something happened yesterday that suddenly prevented my DVD drives from recognizing DVD disks (They both still recognize CDs okay.) If I insert any DVD (whether blank or a commercial movie, etc.) into either DVD drive, I now get an error message saying, "Please insert a disk into drive [L: or J: depending on the drive]." Windows Media Player will recognize the drives if a CD is inserted but not if a DVD is inserted. Similarly, Nero reads and burns CDs okay in both external DVD drives but will not recognize inserted DVD disks in either drive. I can't think what I may have done in the last 24 hours to cause this change. I've uninstalled and re-installed the drives, and I've tried updating drivers (no updates appeared to have been necessary), to no avail. That both drives are similarly affected suggests to me that the problem lies not with either drive (installation, drivers, connections, etc.) but rather with the system. Any ideas?
The two external USB DVD RW drives referred to are the LG GSA-5169D and the Mad Dog Multimedia Dominator USB 2.0. I am using a stand-alone desktop powered by a Pentium 4 (1.8GHz), Win XP Home SP2.
jim2148
jim2148 :
Don't forget where you post ... check it out
https://forum.videohelp.com/viewtopic.php?t=284589
Edit : removed because moderator moved item before finalizing post to other topic -
@jim2148:
1) Please don't cross post.
2) Please don't hijack threads. Start your own, even if your problem tangents the OP issue. I've split this out as a new thread - You can edit the subject if you so wish.
3) Don't go grave robbing (waking up long dead threads).
/Mats
Computer wonīt recognize DVD disk
By dexter30 in forum MediaReplies: 10Last Post: 4th Sep 2010, 14:52 -
PC won't recognize burned files to DVD
By browndav in forum MediaReplies: 6Last Post: 9th Jan 2010, 15:43 -
Toshiba DR2 Won't recognize DVD-RAM any more
By jpc82 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 27th Dec 2007, 09:31 -
Sonic won't recognize DVD, computer does ...
By LittleQueenie in forum Newbie / General discussionsReplies: 2Last Post: 17th Oct 2007, 13:06 -
DVD drives won't recognize any discs
By TIBGustaf in forum DVD & Blu-ray WritersReplies: 10Last Post: 3rd Jul 2007, 07:29
