hey!
in the compatibility list. it say it should play svcd?
however i have tried about 10 diffrent movies.. and none of them worknormal vcds work fine though..
anyone know if u need to do something special when its svcd?
help is greatly apreciated!!
Tools you need: TMPGEnc to convert videos at mpeg-2 and Vcdeasy, with these application you can make your own SVCDs.
TMPGenc:
-start TMPGEnc
-load video source
-load the correct SVCD Template (NTSC or PAL)
-load unlock template (dir Extra)
-now in TMPGEnc Settings Select under Rate control mode Constant bitrate(CBR) and use 2500 Kbit/s
*-or try Constant quality(CQ) in settings as Maximun 2500 kbps(instead of 2520 kbps) and Minimun set to 0 or 300 kbps
-VBV buffer size set to 224 KB instead of 112 KB
-start encode
Vcdeasy:
-Select SVCD 1.0
-Select your CD Writer
-Name the CD
-Select where to make the temporarily output
-Add your SVCD mpg file(s)
-Now it is just to hit Go
Sony dvp-sr100
By deyangg in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st Oct 2011, 03:54 -
My Sony DVD player SONY DVP- NS718 H
By samyer in forum Newbie / General discussionsReplies: 1Last Post: 2nd Feb 2010, 23:56 -
Sony DVP F25
By jimclevs in forum DVD & Blu-ray PlayersReplies: 0Last Post: 5th Jan 2009, 04:17 -
HELP !!! Please !! Sony DVP-S7700
By adamsj13 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 14th Oct 2007, 04:04 -
Sony DVP-NC85H
By jduffy in forum DVD & Blu-ray PlayersReplies: 1Last Post: 6th Jun 2007, 10:17
