Can anyone help,
I've had thisd prblem come up before as regards burning, there was not enough phsical memory then so i bought another memory stick, so i've now got 256mb,that was only last week,and when i put the new memory stick in it was burning ok.
But now i think i've got the same problem as it shows below, can anyone sugest what is best and is there a way to get rid of some of the memory that i'm using, but i can't uderstand why it is ok one minute than in a matter of day's it's back to normal. Thanks
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 17:35:34
Nero API version: 6.6.0.18
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Internal Version: 6, 6, 0, 18e
Recorder: <LITE-ON DVDRW SHM-165P6S>Version: MS0M - HA 1 TA 1 - 6.6.0.18
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
=== Scsi-Device-Map ===
DiskPeripheral : ST320413A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : LITE-ON DVDRW SHM-165P6S atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
LITE-ON DVDRW SHM-165P6S D: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 40894464 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 255MB (261620kB)
Free physical memory: 24MB (25512kB)
Memory in use : 90 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
16.1.2007
NeroAPI
22:47:11 #1 Phase 112 File APIProgress.cpp, Line 276
DVD-Video files reallocation started
22:47:11 #2 Phase 114 File APIProgress.cpp, Line 276
DVD-Video files reallocation completed (no file modified)
22:47:11 #3 Phase 111 File APIProgress.cpp, Line 276
DVD-Video files sorted
22:47:12 #4 Text 0 File Reader.cpp, Line 127
Reader running
22:47:12 #5 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
22:47:12 #6 Text 0 File Writer.cpp, Line 122
Writer LITE-ON DVDRW SHM-165P6S running
22:47:12 #7 ISO9660GEN -11 File geniso.cpp, Line 3309
First writeable address = 0 (0x00000000)
22:47:12 #8 ISO9660GEN -11 File geniso.cpp, Line 3309
22:47:12 #9 Text 0 File Burncd.cpp, Line 3233
Turn on Disc-At-Once, using DVD media
22:47:12 #10 Text 0 File DlgWaitCD.cpp, Line 270
Last possible write address on media: 2297887 (510:38.37, 4488MB)
Last address to be written: 579759 (128:50.09, 1132MB)
22:47:12 #11 Text 0 File DlgWaitCD.cpp, Line 282
Write in overburning mode: NO
22:47:12 #12 Text 0 File DlgWaitCD.cpp, Line 2483
Recorder: LITE-ON DVDRW SHM-165P6S, Media type: DVD-RW
Disc Manufacturer: RITEKW - 01
Disc Application Code: 64, Disc Physical Code: 214
22:47:12 #13 Text 0 File DlgWaitCD.cpp, Line 448
>>> Protocol of DlgWaitCD activities: <<<
22:47:12 #14 Text 0 File ThreadedTransferInterface.cpp, Line 838
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 579760 (579760) = #579760/128:50.10
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 579760 blocks [LITE-ON DVDRW SHM-165P6S]
22:47:12 #15 Text 0 File ThreadedTransferInterface.cpp, Line 1051
Prepare recorder [LITE-ON DVDRW SHM-165P6S] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 1187348480, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
579760 | lead-out | 1 | 0x41 | 0x00
22:47:12 #16 Phase 24 File APIProgress.cpp, Line 276
Caching of files started
22:47:12 #17 Text 0 File Burncd.cpp, Line 4122
Cache writing successful.
22:47:12 #18 Phase 25 File APIProgress.cpp, Line 276
Caching of files completed
22:47:13 #19 Phase 36 File APIProgress.cpp, Line 276
Burn process started at 2x (2,770 KB/s)
22:47:13 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2661
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
22:47:13 #21 Text 0 File DVDR.cpp, Line 2571
Recording mode: Sequential Recording Mode
22:47:13 #22 Text 0 File Mmc.cpp, Line 21774
Set BUFE: Buffer underrun protection -> ON , SMART-BURN : ON
22:47:13 #23 Text 0 File DVDR.cpp, Line 2726
Start write address at LBA 0
DVD high compatibility mode: Yes
22:47:13 #24 Text 0 File Cdrdrv.cpp, Line 8892
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-RW (3), Part Version: 1.1x (2)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: BD8AF h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
80 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
22:47:58 #25 Text 0 File Cdrdrv.cpp, Line 1288
22:47:58.327 - LITE-ON DVDRW SHM-165P6S\H1 T1 : Queue again later
23:00:04 #26 SCSI -1135 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x00BE0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x04 0xE5 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
23:00:04 #27 CDR -1135 File Writer.cpp, Line 311
Write error
23:00:04 #28 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
23:00:04 #29 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
23:00:04 #30 Text 0 File DVDR.cpp, Line 2969
EndDAO: Last written address was 320767
23:00:16 #31 Phase 181 File APIProgress.cpp, Line 276
Writing lead-out...
23:00:16 #32 Text 0 File DVDR.cpp, Line 3002
Estimated time for 30mm Borders: 2min 53sec
23:00:16 #33 Phase 38 File APIProgress.cpp, Line 276
Burn process failed at 2x (2,770 KB/s)
23:00:16 #34 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
23:00:16 #35 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.03.32a, size=20640 bytes, created 27/07/2006 17:28:33 (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
You are getting buffer underruns on your burner. First thing to try is to deframents your hard drives. What in the world is a 100GHZ processor that you mention in your profile? No such thing not even in your dreams!
Doesn't seem to know what to do with your media (unrecognizable?)
(IMHO, 512MB is the least I would use with Windows XP, less hard drive grinding when it needs memory) -
Would it be a good idea to do a memory optimizer to see if i'm leaking any memory somewhere.
Just wondering if you started the problem burn's after doing other things on the pc .
A 100ghz ... I want one of those briskets ... lol
There are tool's for testing the memmory > http://www.memtest.org/#downiso ...
Grab the second iso below * Memtest86+ V1.65 (10/01/2005) * on that page .
Extract it from zip , burn the iso using imgburn , restart pc (it's 900kb , tiny)
Set bios to boot from cdrom , disable all other boot option's , (the iso cd is still in the cd/dvd tray) , save , and system will reboot .
From there on watch the screen for info regarding how to use it .
After , depending how it requires the exit function , restart the pc , and head back into bios , and reset those drive setting's back to what they were beforehand ... remove the disc , save , and your back in the os once more .
Then it's up to you too determine what the memmory result's are ... you can alway's get help here .
Shut down the system , take the power cord out of the back after you have turned it off .
Remove both memory chips .
Check the contact's are clean , and the slot's , then swap them around , and refit .
If you defraged the hard drive ... I wonder what the system swap file is , as this has to change when extra memory is added .
Start , settings , control panel , system , advanced tab , performance settings button , advanced tab ... what dose it list as the system doing here .
You might want to set it too system managed size , and try once more . -
You have little memory and only 24mb free.
You should consider a proper upgrade to at least 512mb.
You should check your virtual memory size and consider increasing it - assuming you have enough hard disk. This should be on the internal hard disk.
If you are burning files from your external hard disk, that could also be contributing to underruns.
You might consider replacing this antique system rather than further upgrades. An 18gb system drive is not very large when manipulating 4gb or greater movies. An external USB or firewire drive is a slow solution to more storage and does not solve all system disk needs. It particularly bad when combined with other underpowered system components.
XP had many features which will clutter your primary disk drive with files that will decrease your performance. You have little to spare.
Nero is caching to your primary drive.
Do you have any free space on drive C
I've just purchase another memory stick so i've now got 640mb,i've got 9.8gb of space on my internal harddrive,and 31.4gb on my external hdd, also since i've put the new memory stick in my pc seems to be running faster.
I've also got spyware doctor running in the background that i installed last week,come to think of it thats when i satrted to run low on memory.
Is it possible that that could be taking up a lot of memory?would i be better off installing adware that does not run in the background and uninstalling spyware doctor. -
If you are worried about memory leaks, open Task Manager and select the Processes tab. Click on the Mem Usage column to sort by memory usage. Sit back and watch. If you see a process continually increasing memory usage, that's a likely a leaker. (Don't worry about the column named Page Faults).
John Miller
PC memory
By alintatoc in forum ComputerReplies: 17Last Post: 17th Nov 2009, 17:24 -
Vegas 8 - "System low on memory. You may be able to reduce memory usag
By sdsumike619 in forum EditingReplies: 12Last Post: 12th Nov 2009, 05:16 -
Memory
By ProducerHarley in forum ComputerReplies: 1Last Post: 3rd Dec 2008, 00:38 -
I just adeed another 2GB Memory and Total says 3.25GB Memory
By videocheez in forum ComputerReplies: 17Last Post: 11th Feb 2008, 06:19 -
I'm still trying to determine how much memory is in thus USB memory stick.
By zzyzzx in forum Off topicReplies: 4Last Post: 5th Nov 2007, 14:31
