What's the best way to break up a larger then 700meg image to 2 disks.
Patrick
No Way. You will need to re-author and create two separate images. By the way a 700 MB VCD image should fit on 80 min disks.
Thanks.
Well, I'm asking for someone else. They have a 746Mb Mpeg2
file or some size like that, and can't get it onto one disk.
I have not tryied this yet but always thought that the burn program would span a cd for you.
Patrick -
A 746MB image will fit on 1 80 min CD in mode2/form2 format, which is what VCD/SVCDs are written in.
Windows7 image backup - restoring the image question
By ranchhand in forum ComputerReplies: 18Last Post: 15th Apr 2012, 08:13 -
Printed page image don't equal PC monitor's image?
By bryankendall in forum Newbie / General discussionsReplies: 9Last Post: 11th Nov 2008, 14:45 -
Vegas 8 - replace an image with image from previous frames
By sdsumike619 in forum EditingReplies: 2Last Post: 5th May 2008, 15:26 -
Vegas - add image to video (DVD(mpg)) and moving image around
By psxiso in forum EditingReplies: 4Last Post: 11th Jul 2007, 05:29 -
How to post an image instead of a link to image?
By fLYtRap in forum FeedbackReplies: 11Last Post: 5th Jul 2007, 13:55
