  1. do you guys know of any other good codecs similar to divx or wmv9vcm or xvid (which I'm not a big fan of)? I mostly use virtualdubmod to encode fitcd files (avs). Most of the time I use divx6 which is great, when I have problems with divx6 I use wmv9 vcm, which doesn't look as good, but does the job. xvid is similar to wmv9 in that aspect. Are there any high quality codecs I should get, that compress well like these?
    Thanks guys.
    a.m.
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    For playing back on what? One of the factors to consider is the intended audience. Another is file size. I could suggest DV (that'd beat the living daylight out of any of those mentioned qualitywise) at the cost of 13 GB/hour.
    /Mats
  3. For playback on a dvd player. The file would be burned on Nero express onto a regular dvd. Yeah I tried DV that's really huge lol
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    That pretty much limits your choices to XviD and DivX, unless you got a very special DVD player AFAICS...
    /Mats
