I am trying to decide on which capture card would be better
WinTV or Pinnacle Studio PCTV Pro. If some one could please shine some light on it for me it would be great.
Thanx
Neither cards shines above the other, But in terms of picture quality the Pinnacle gains a slight edge on the WinTV.
YOU'RE WARNED: if you buy the Pinnacle you will NOT, I repeat NOT receive ANY technical support from Pinnacle systems. As far as I'm concerned they've trained a bunch of monkey's to cut and paste the same FAQ's over and over whenever you email them regardless of what you ask them
Just ask Dave Zegglins their head CUT & PASTE monkey.
I have a friend who use to use the WinTV and both of our captures came out nearly identical. My PCTV had slightly more color than has WinTV and his ATI TV wonder; only GOD knows why the man used to different tuner cards for capturing.
<font size=-1>[ This Message was edited by: deadpac on 2002-01-17 11:41:17 ]</font>
